Use the following procedure to display the IS-IS LSDB and adjacencies.
Switch:1>show isis lsdb
ISIS LSDB
LSP ID LEVEL LIFETIME SEQNUM CHKSUM HOST-NAME AREA
0014.c7e1.33df.00-00 1 545 0xb1 0xed28 NewYork HOME
0016.ca23.73df.00-00 1 1119 0x9f 0x9c9d Switch-Lab2 HOME
0018.b0bb.b3df.00-00 1 708 0xb9 0xcb1a Switch-Lab1 HOME
Level-1 HOME AREA: 3 out of 3 Total Num of LSP Entries
Level-1 REMOTE AREA: 0 out of 3 Total Num of LSP Entries
Level-2 HOME AREA: 0 out of 0 Total Num of LSP Entries
Level-2 REMOTE AREA: 0 out of 3 Total Num of LSP Entries
Switch:1>show isis adjacencies
ISIS Adjacencies
INTERFACE L STATE UPTIME PRI HOLDTIME SYSID HOST-NAME STATUS AREA AREA-NAME
Port1/11 1 UP 05:02:18 127 22 beb0.0000.7204 Switch-Lab1 ACTIVE HOME area-9.00.02
Port1/12 1 UP 05:00:18 127 25 beb0.0000.7204 Switch-Lab2 BACKUP HOME area-9.00.02
Port1/16 1 UP 05:00:25 127 24 beb0.0000.7204 Switch-Lab3 BACKUP HOME area-9.00.02
Home: 3 out of 3 interfaces have formed an adjacency
Remote: 0 out of 0 interfaces have formed an adjacency
Switch:1> show isis lsdb detail
ISIS LSDB (DETAIL)
Level-1 LspID: 0001.bcb0.0003.00-001 SeqNum: 0x00000522 Lifetime: 1144
Chksum: 0x32f7 PDU Length: 312
Host_name: C0
Attributes: IS-Type 1
TLV:1 Area Addresses: 1
c1.3000.0000.00
TLV:22 Extended IS reachability:
Adjacencies: 7
TE Neighbors: 7
0000.beb1.0007.01 (Switch0) Metric:10
SPBM Sub TLV:
port id: 640 num_port 1
Metric: 10
0000.beb1.00b1.01 (Switch1) Metric:10
SPBM Sub TLV:
port id: 643 num_port 1
Metric: 10
0000.bcb1.0004.01 (C1) Metric:10
SPBM Sub TLV:
port id: 6144 num_port 1
Metric: 10
0000.beb1.00ca.01 (Switch2) Metric:10
SPBM Sub TLV:
port id: 6156 num_port 1
Metric: 10
0000.beb1.00a5.01 (VSS0) Metric:10
SPBM Sub TLV:
port id: 651 num_port 1
Metric: 10
0000.beb1.00b2.01 (VSS1) Metric:10
SPBM Sub TLV:
port id: 645 num_port 1
Metric: 10
0000.beb1.0008.01 (Switch1) Metric:10
SPBM Sub TLV:
port id: 652 num_port 1
Metric: 10
TLV:129 Protocol Supported: SPBM
TLV:137 Host_name: C0#
TLV:144 SUB-TLV 1 SPBM INSTANCE:
Instance: 0
bridge_pri: 0
OUI: 00-33-33
num of trees: 2
vid tuple : u-bit 1 m-bit 1 ect-alg 0x80c201 base vid 1000
vid tuple : u-bit 1 m-bit 1 ect-alg 0x80c202 base vid 1001
TLV:144 SUB-TLV 3 ISID:
Instance: 0
Metric: 0
B-MAC: 00-00-bc-b1-00-03
BVID:1000
Number of ISID's:8
3001(Both),3002(Rx),3003(Both),3004(Rx),4001(Both),4002(
Rx),4003(Both),4004(Rx)
Instance: 0
Metric: 0
--More-- (q = quit)
The following table defines parameters for the show isis lsdb command.
Variable |
Value |
detail |
Displays detailed information. |
home |
Displays the IS-IS LSDB information that the system configures in the home area. |
level {l1|l2|l12}] |
Displays the LSDB for the specified level: l1, l2, or l12. |
local |
Displays IS-IS local LSDB information. |
remote |
Displays the IS-IS LSDB information that the system configures in the remote area. |
sysid <xxxx.xxxx.xxxx> |
Displays the LSDB for the specified system ID. |
lspid <xxxx.xxxx.xxxx.xx-xx> |
Displays the LSDB for the specified LSP ID. |
tlv <1–236> |
Displays the LSDB by TLV type. |
The following table defines parameters for the show isis adjacencies command.
Variable |
Value |
home |
Displays the IS-IS adjacencies that the system configures in the home area. |
remote |
Displays the IS-IS adjacencies that the system configures in the remote area. |
The following table defines parameters for the clear isis command.
Variable |
Value |
lsdb |
Clears the IS-IS Link State Database (LSDB). The command clears learned LSPs only. The command does not clear local generated LSPs. As soon as the platform clears the LSDB the LSP synchronization process starts immediately and the LSDB synchronizes with its neighbors. |
